I recently picked up a pair of KLH Model 6s (screwed woofer, not glued) and found that the tweeter in one of them sounded a bit weak. I tried flipping the channels from my amp to check if that was the issue but it persisted in the same speaker, and after a recap today it's still the same. The tweeter does produce sound, but it sounds 'airy' for lack of a better word, and a bit lacking in power and midrange. Does this seem like a tweeter on its way out or possibly just a resistor? I'm quite new to working on audio equipment so apologies if it's an obvious answer.
EDIT: After doing a bit of research I've realized I made a mistake during the recap - the original 2uF capacitor in there is apparently a parallel cap (hence the two leads coming out of one end and why I have two leftover 2uF caps...). I don't believe this is causing the issue because the one tweeter is fine but I'll have to get back in there and fix this up at some point. Rookie mistake!
Thanks
Thanks
