GD70
Lunatic Member
Thanks Robert!
I'm away and on my iPad, and couldn't figure out how to copy the web link.
Cheers, Glenn
Thanks Robert!
Never seen Sixes with a potentiometer for tweeter output adjustment.
So to help with some clarification......
Thanks Tim (and Glen). I ordered new capacitors today, and will start the take down process next week. I'll follow advice and go slow. Fortunately I don't have to refinish the cabinets, and the cloth covers are still in excellent condition. If I can get at everything from the crossover cover, I'll be in good shape. I found the original manual with the crossover diagrams on line, so I have some idea of what the connections should be. I expect that it will be challenging to reach the 8 microfarad caps. In any event, this seems to be the place to start, given the inaccessible location of the tweeters.
As far as I know, the two tweeter version are exactly the same.pvs,
While you are in there replacing the caps if you have a multimeter you can check the tweeters. Glenn can confirm, but the later model Sixes had tweeters that ran about 4.7ohms DC resistance. Not sure if the early model epoxied tweeters have the same DC resistance. Basically you would be verifying that they aren't open circuit (dead).
I found the circuit diagram in an on line post of the original manual, but didn't write down the attribution. Thanks to whoever uploaded, and I hope you don't mind my sharing it
If there's oil caps in there, leave them! They hold up very well.Yes, that's the right diagram. I have never seen any other variations, but often in the ones with electrolytic caps you'll find two caps in one tubular case with 3 wires coming out. One wire is a common for both caps inside. You just replace it with two individual caps and tie one end of the two together. Yours is early enough that unless someone has been inside it will still have the original oil caps and probably won't see those double electrolytic caps. You'll know it because the oil caps are in metal cans.
Yes they are! Did you remove the grills to reseal the woofer surrounds and dust caps? If you think the bass is good now, once resealed, you'll be shocked how much deeper they will go.Second speaker recapped. Great sounding speakers. It was worth the effort. Thanks to all for your help
