Agree.If that pic in the previous post is any indication, those are the correct drivers. It also looks like the original cloth surround is intact. Is that correct?
Agree.
I would not hook them up to that receiver until after the repairs and at least a couple weeks testing on the Minimus 7's after the repairs. Not worth the risk ruining another set of woofers. I would even more be thinking to get another, newer amp or receiver. Becoming a member, well worth it, and helps support AK, will allow access to Barter Town, where there are plenty of exceptional pieces of restored gear for very reasonable prices.
The Six is an exceptional, iconic, vintage speaker. Worth restoring and enjoying for many years. Please post lots of detailed pice asap!
Glenn
The surround is the U-shaped yellow circle on the outside of the cone. The weatherstripping under the frame is fine, that's just to prevent leaks.
Becoming a subscriber is easy. Go to the home page, click the Subscribe button, and pay. Done! A great way to start the New Year!I agree with your plan-I like the Sherwood because of its tube like sound but not at the cost of it being unreliable-and it's better to experiment on the 7's than the 6's. I hope to be able to keep them more so than the receiver. Now I have to find out how to join Barter Town. Thank you.
View attachment 1718872 View attachment 1718875
It's U-shaped when viewed on edge, which you can't do without cutting it apart, but don't worry, you've found it. It's what enables the woofer to move in and out while keeping the cabinet sealed.apparently it's the yellow padding around the outer edge-not sure what the "U" refers to-in that case my surrounds are fine-
Thank u-I have a habit of asking about something and then finding it on my own-Becoming a subscriber is easy. Go to the home page, click the Subscribe button, and pay. Done! A great way to start the New Year!
It's an annual subscription.
right-The Sherwood's going back to the fit-it guy tomorrow-
he either made an error, installed faulty part(s) Or there is a different issue-,
I agree with you in theory-but I've never met anyone who would do be that meticulous-I have ask for that information and all I got was a dirty look-There are only 3 people around here that repair hi-fi equipment, and I'm not one of them, the other two are less than honest, and the person who repaired the Sherwood was my last hope-It did work for a few weeks w/o issue until the repaired problem came back-Taking it back to him now-we'll see how it's handled-Anytime somebody claims something has been repaired/restored/refurbished/tested, there should be a very detailed written list of what was replaced with what, what was adjusted/tested/measured and what the adjusting/testing/measuring results were.
The surround is the orange part that joins the speaker cone to the metal basket in your picture. They are made of cloth and seldom fail. It is circular because the cone is circular. The reference to "U" is because of the ditch shape of the surround is like a "U" shape. That "U" shape gives the surround some slack so that the cone can move in and out to the music.
Per the photos, your surrounds look to be in good shape but due to the age they will need to be treated with a rubberized goo. That goo is a sealant that was applied at the factory to ensure that air is no passing through the surround (and dust cap too). After 50 or more years the sealant would definitely need to be re-applied.
So why did you think you needed new surrounds? What part do you think has gone bad that you thought was named "surround"?
It's possible you have a short from the voice coil to the frame of the speaker that could overload your amp. Gently and slowly push the cone down, and listen for any rubbing noise as the cone travels up and down.I agree with you in theory-but I've never met anyone who would do be that meticulous-I have ask for that information and all I got was a dirty look-There are only 3 people around here that repair hi-fi equipment, and I'm not one of them, the other two are less than honest, and the person who repaired the Sherwood was my last hope-It did work for a few weeks w/o issue until the repaired problem came back-Taking it back to him now-we'll see how it's handled-
I got an S-7200 as-is off the shopgoodwill site a few years ago and was making weird wave noises in the background when I got it that soon became static crackling type noises. Using freeze spray that indicated the 2SA666 differential pair was the offender on the bad channel. Replaced the pairs on both channels with KSA992 and problem gone.
Recapped and replaced some transistors in the S-7200, the 2SC693Fs on the tone board were generating a good bit of white noise. Replaced all four with KSC1845 if I remember. Nice sounding receiver, one of the favorites in my collection. No relay or protection circuit on it, like many uses fuses.
Bought an untested (no cord) SX-636 from binkman cheap saw 3 2SA726 and what I guess was an NTE replacement replaced those and the 2SC1451 and ended up with a nice sounding receiver that works well, probably some recapping is due. He said he tested it and got a lot of crackling and put it on CL. I replaced those transistors and put a cord on it surprised when I brought it up was stable and worked well. Has issue with AUX thinking it may be a bad cap but tuner works well.
A few weeks ago picked up a badly crackling Sansui 771 when person demoed it the noise overwhelmed the tuner output even tripped the protection relay periodically. New differential pairs (2SA726s again) and DC stable and no noise. Been enjoying the 771 over the last 2 weeks.
With what voltages I saw out of the 771 when I put DVMs on the outputs in DC voltage mode before transistor replacement its possible a woofer got damaged. He may have only one bad. Then again the voltages in that situation often are not that high so he may be okay. On the 771 one channel was getting much higher voltages than the other, one stayed under a few hundred millivolts other went to a volt or two.
You can push the cones to the outer ranges just using a battery (AA, AAA, C, D whatever is handy and two wires) swapping polarity will change direction. Do to both and see if the cone moves in and out the same or different. If one has displacement symmetrical it should be good. Also carefully push cone in and out feeling for voice coil rub. Overheated voice coils can drag which you can feel. Comes from a simple DIY speaker building check to get an idea of the damping of the woofer in the cabinet.
Here are pics of a speaker I replaced the surrounds on. One pic is the surround, one is the repaired speaker with new surround, and one is the speaker being measured for the surround with the old one removed.
Hey, thanks gonna go look it up-nice pic-130 bux at your nearest Target:
