KLH Model Twenty Three find
wingman65
Member
Found a very nice pair of KLH Model Twenty Three cabinets with crossovers but NO drivers at local GW for 20 bucks. It seems from my research that this was a fine speaker though drivers are hard to come by compared to the overproduced model six. Is this a worthwhile speaker to restore and hold out for model 5/23 drivers? It seems that all the idiots on auction sit list the 6 drivers as a match with the 23 but it is my understanding that only the harder to find model 5 drivers are a match with the 23. Here are pics of the cabs.
2 thoughts....model 6 woofer with either a modern Seas tweeter or maybe do what they call a FAST...run the woofer up to 400hz and cross it to a Mark Audio Alpair 7.3:thmbsp:. You will need a 2 liter internal enclosure for the Alpair driver.
A lot of times, people will part the old KLH's out because they have dead tweets when a recap was all it needed. The woofs are pretty much indestructible and have cloth surrounds.You might as well replace the caps and then just hold out for the woofs and tweets. They do surface regularly.You are correct, the model 6 woofer will fit a 23, however it has a lighter magnet than the 5/23. I do think that the tweet for the 5/23/6 is the same. The tweet for the 17's and others look the same but are tuned slightly differently.
Actually the tweeter for the Twenty-Three, Five and Twelve is different from the Model Six, Seventeen and Twenty (and other similar model) tweeter. It will fit however, and the difference is very subtle, so if replaced in pairs you are not likely to notice any difference.
The Twenty-Three style tweeter has a lighter, more articulate sound to it and is damped differently at the factory. Electrically it measures the same but with it's internal differences it tends to be less "squawky" sounding in the upper mids.
The only real way to spot the difference is the glue used to hold the screen in place on the front. The Twenty-Three, Twelve and Five tweeter uses a brown adhesive whereas the other lower model tweeters use a light tan adhesive.
Thanks for the tips. It certainly seems that the devil is in the details with these early KLH drivers. I wish I could find more information on them.
Thank you AudioJones for the kind correction on the tweets. This is what AK is all about!
Picked up a set of 23's and a set of 17's a week ago. The 23's have blown my mind. I just ordered some Precision Daytons to replace the original caps to improve the highs. I have a feeling the 23's are never leaving my home. As for the 17's, one had a bad tweet and a replacement has been ordered and those will do duty in the dining room. If you can holdout and keep your eye for drivers Wingman, I think you would be very happy with the 23's.
Sometimes tweets are dead in KLH's when caps are bad. Fact is that was the case in my model 6's and 23's. After recap, they worked perfectly. I agree the 23's are keepers. The 17's are very special, especially in a smaller listening area. What I have found with the KLH's is they have great synergy with my vintage gear and not so much with modern surround gear. The surround gear is currently boxed up and put away.
You should definitely hold out for the KLH drivers. EBay has them very often. I have two pair of 5's and they are really wonderful with my 1970's Kenwood system, I totally agree with the synergy of matching speakers with their contemporary amplifiers.
Great find,
Rob
I was really hoping that to be the case but upon testing, the tweet is in fact dead. Switched the tweeters from speaker to speaker and still nothing. Think I will go ahead and order the caps for them also. I plan on keeping them as well. I have been acquiring quite a lot of vintage items and as I do, the modern stuff has gone out the door. I do have the 23's hooked to a modern Sony ES using a Marantz AV8003 pre-amp with audyssey and I must say it actually really sounds amazing. I do prefer the Sansui 2000x with them tho.
Wingman65, just wondering..are you a 117 driver?
No, I just like its sexy lines:yes:
Problem with the drivers on ebay is knowing what they are. They list the SIX and Twenty Three as the same but the six drivers are different. The five and twenty three being the same and my understanding is that the 6 and 23 are crossed over quite differently. The six drivers may work but I want to be sure to have the proper 5/23 drivers.
Yeh, I saw that listing. The 23's blow me away with how good they sound, especially with only a single 4uf cap. The six's take a 2uf and an 8uf (I think) as do the 17's. Maybe you should turn the 23's into a "Frankensix" LOL!.
Wingman65, after closer inspection of the photos of the Model 23/6 woofer posting on ebay. That is a model 6 woofer. The 23/5 can have a round or square magnet but it is much larger.
The Twenty-Three, Five and Twelve woofers will not only have larger magnet structures but they will also usually have the cone weight (in grams) written on the front of the cone in magic marker. Typical weights are between 22~27 grams to the nearest tenth of a gram (22.6, 27.3 etc).
The other models of KLH woofers will sometimes have the model that are made to go into written on the cone (6, 17, 20 etc).
Apparently the size of the magnet is the only identifiable way to tell. maybe weight difference is needed to know for sure. Certainly not the most gorgeous driver but have a reputation for sounding good:yes: Worst case scenario, I can make them a six and still not be disappointed in their sound:smoke:
Well like I said before a "frankensix".. If you did that, you'd need to change the crossover to that of a six I would think. Probably just best to wait until the right woofs come up.
You are right not a real "looker". KLH actually manufactured their own woofers and actually integrated a cotton blend into mixture. The woofs are virtually indestructible, and on the whole KLH's are easy to recap and restore. That's why there are still a lot of them out there. Especially the 6's and 17's which had lower price points.
