KLH Six: Tutorial...?
ivan100000
Well-Known Member
Good afternoon--
I have a single KLH Six in my mono system that I bought replacement Dayton caps for about a year ago, but due to my soldering skills being so weak and the fact that I am an electronics idiot in general, I have been putting it off. The original caps have gotten so bad that my records devolve into fuzz after just a few minutes of spinning on the turntable, and it's to the point where I can no longer tap on the back of the crossover plate to improve the sound quality. As a result my system has sat in silence since early summer.
I'm inspired today to the extent that I've brought the soldering stuff up from the garage and opened the Parts Express box with the caps/putty/heat shrink tubing, but I cannot locate the excellent, step-by-step online tutorial I thought I'd saved. I am finding a tutorial for the earlier Six model that's epoxied, but mine is the later style with the removable woofer.
Can anyone steer me in the right direction as to where I might find a clear, concise online tutorial to help me through the project?
Thank you!
No better place than right here. You are going to have to remove the woofer and get at it from the inside.
Post pics here and there will be lots of help to walk you through it.
Tricky part is if these have the caps set in epoxy. Requires chipping it out to get at the wires etc. Used a big ol' pocket knife with sharp point to get the old caps free.
Use the search feature here on AK and you will find tons of information.
Good luck, the Six is a classic for a reason.
For which part of the process do you need a tutorial? Remove woofer, replace caps, apply sealant, reinstall woofer.
Hello Borchee--
Point taken, but I did make mention in my original post of the minor detail that I am an electronics IDIOT. I need the thorough, detailed photos from the tutorial someone posted a while back that I cannot now locate, so I know which of the two caps I am to replace with the strapped-together doubles, how I secure the new caps to the side of the cabinet, which capacitor legs need the heat shrink tubing, etc.
You're overthinking this - electronics has nothing to do with it.
All it takes is:
Follow it!...remove the woofer and see what's inside - it ain't that much.
You have two(three) capacitors and five joints/solder points.
The strapped together doubles (only on one side!) replaces the double capacitors with three leads.
None of the legs need shrink tubing per se, but use it on all of the five blank points/legs/wires nevertheless.
How to secure the caps to the cabinet?...hot glue...silicone sealant...rubber cement...chewing gum...
Show the replacement capacitors.
Hello Borchee--
Point taken, but I did make mention in my original post of the minor detail that I am an electronics IDIOT. I need the thorough, detailed photos from the tutorial someone I cannot now find, so I know which of the two caps I am to replace with the strapped-together doubles, how I secure the new caps to the side of the cabinet, which capacitor legs need the heat shrink tubing, etc.
You’re not an idiot. You haven’t done it before dude. Believe in yourself. You can do this.
You CAN! If you can make toast, you can figure it out. Got hand tools?
Buy a cheapy Weller 25 watt pencil iron, some 60/40 rosin core solder, find an old trashed radio or something and start burning the toast!
My advice is to find a piece of wire and cut it in half and then start practicing attaching the wires together and soldering them together. Part of the goal is to learn how to make a good solder connection that shows no sign of a cold solder connection. One step at a time. If you try to do it all at one time, it may discourage you from getting involved in the task.
OP here. I’ve finally removed the woofer, and this is exactly what I was afraid of: this one has already been (crudely) worked on, and I have no idea what I’m looking at. Any advice?
OK, what you need is a schematic of the KLH 6 crosover (I do not have one) to use as a road map. You can lay the parts out on your workbench to see how they should go together. The schematic is not a wiring diagram, but shows electrically what should be attached to what. It's a pretty simple circuit.
I think @sound hound had an excellent idea of playing with soldering wire beforehand to learn that skill (what I did with my son, with great success, before he worked on electric guitar wiring ;)) You can do this! But expect to spend a few hours learning before cutting things apart in your speaker...
Hello, and thanks.
A man's got to know his limitations.
I didn't want to spend my day off driving an hour and a half each way to the highly-recommended speaker repair place, but for $120, it's worth the peace of mind to have a pro clean up the rat's nest and do it right. Next time the caps need to be replaced in another 50-60 years, it will be someone else's problem.
The woofer itself looks pretty much intact, other than some lugnut has bent the terminal plate down way out of its normal position, putting the voice coil leads at risk.
Oh, yeah, looks like you have the Model Six type with just two input terminals rather than the type with three terminals as shown above. Looking at your pics a little closer it does appear that someone has been in there messing around ... who knows? Snipped and resoldered wires on the woof, the bigger yellow 8uFd capacitor just flying around in there. Anyway, the black capacitor on the back panel is what you were referring to as the "double", two capacitors in a single container. You'd just replace it with two separate 2uFd caps and twist the leads on one end together, soldering the twisted leads to the existing lug on the back panel. The other ends of the 2uFd caps would go to the respective terminals on the switch.
You're probably right to take it to "the guy". Sounds like you just want to listen to tunes rather than learn stuff.
It isn’t so much that I don’t want to learn; I just don’t have the aptitude for electronics to begin with, and when there are semi-blurry pictures of a crossover online from the older epoxy model, I’m just sort of guessing at what to do. The wiring to this speaker had evidently been hacked up by my older brother and his friends in the ‘70s when they were like 13, and there were wire connections taped with duct tape by the tweeter as well as a huge paper capacitor dated 11/58 that was way up by the tweeter.
Forget it—I didn’t want to spend half the day trying to make solder connections I wasn’t sure about to begin with down in never-never land behind the tweeter. If there were someone here showing me what needs to be done and explaining the theory behind it then I would be anxious to learn. The guy I brought it to this afternoon said it will be closer to $200 to straighten out the wiring, solder in the new caps, dope the speaker, etc. I don’t mind the $200 as much as having to waste 1hr 45 minutes driving each way on my day off, but so it goes. When I pick it up in 2 weeks I will be done with speaker problems!
Hello!
Like you, when I started to get more into vintage audio, I didn’t know jack sh*t about speaker electronics.
I also started with a set of late model Sixs from a thrift store.
Members here guided me through the recap process, and it’s very easy to do.
I did have soldering skills, but that’s very easy to learn. Here’s the link to my thread that should help you feel confident to do this yourself.
Cheers!
Glenn
I have a pair of early 6's that I've been avoiding because everything I've seen tells me it's going to be a time consuming pain in the ass. I'm cheap though, so there will be no repair shop.
My KLH experiences started out with a couple of slightly mismatched non-functioning early Model 6. It was perplexing, for sure, but ended up with a pair of pretty nice speakers! In my case, the most important thing was taking it in small increments and having a place to keep the pile undisturbed while disassembled. It took a while to complete the project but I think it was for the best.
