boreas
"If it sounds good, it IS good." E.K.E.
Got a pic of a 6 and a 33.
Okay, I've got a job for you.
John
Okay, I've got a job for you.Pull a tweeter from each and find out whether they have the same thickness top plate. That way we'll know where to place the Thirty-Three, with the Six, etc or with the Five, etc. (I've always heard the Six.)
John
Model Twelve, Five and Twenty-Three tweeters are interchangeable as you first posted.
The easiest (and pretty much the only) way to distinguish the Five/Twelve/Twenty-Three tweeter from the others is by the color of the adhesive used to hold the screen in place. The Five/Twelve/Twenty-Three uses a dark brown adhesive whereas the Six/Seventeen/Twenty uses a tan colored adhesive. You will often find M-12 stamped on the Five/Twelve/Twenty-Three tweeters as well, but not always.
The repair to the voice coil wire is pretty easy to do, I've done a bunch of them and that's usually all that is wrong with them. Heat up a knife or a flat blade screwdriver with a soldering torch and run it around the screen to pop it loose from the adhesive. Attach a very small gauge wire between the broken ends of the voice coil wire and solder it in place. Next use a hot glue gun and bury the wire in a small strip of hot glue (make sure that it doesn't touch the chassis of the tweeter assembly). Run a bead of hot glue around the edge of the basket and press the screen back into place after you have tested the tweeter and you are done.
Seems to be a very common failure, usually caused by corrosion at the soldering points (too much flux at the factory maybe?).
I just attempted this on one of mine and the only way I would get any kind of ohm reading was when I pressed the new wire down onto the brown cone support. When just holding the new wire to both ends of the broken wire, again this was the when I could get a reading, not when just the wire ends were touching. I'm a bit stumped. Also the wire is from some very fine twisted steel cable which I pulled off one strand. Should I be using copper wire instead?
Yes, definitely use copper wire. I usually pull some stands of fine copper wire to do this repair or else I'll use the braided copper voice coil connection wire from a junk speaker (that braided wire that goes from the terminal strip to the cone connection).
If the break in the voice coil wire is below the cone then you're out of luck on that tweeter. If you can get an ohm reading at a point above the cone then that's where you make your connection with the new wire. If you only get an ohm reading when you push in on the cone then you're out of luck, that means the break in the wire is below the cone.
Hope this helps!
*EDIT*- On closer inspection I now see that you are talking about the lower plate on the magnet and you are 100% correct - it is THICKER on the Model Six, Seventeen, Twenty tweeter and THINNER on the Model Five, Twelve and Twenty-Three tweeter. It's very obvious now that you have pointed it out, I will take a closer photo and post it below.
Yeah, the wording in the Service Bulletin confused me too. At first I thought they were talking about the flange.
So, it would seem that there are two ways to distinguish one type from the other, the color of the adhesive and the thickness of the top plate in the magnet assembly.
John
Yeah but the magnet backing plate seems like a very solid structural difference that can't be mistaken if one knows to look for it. Hopefully the picture above will help folks distinguish between the two in the future. Hey, I learned something today - thanks!
Thank the OP! He found that service bulletin on CSP.
John
Here are a few more pictures that may allow someone to see the differences in the two types of tweeters more clearly.
Photo 1 and Photo 2 show the difference in the color of the adhesive and Photo 3 shows the difference in the thickness of the magnets top plate.
I will provide a couple of pictures of the repair of the tweeters once completed.
