Have a nice set of 23’s that may need a tweeter replaced. I have read some conflicting comments about which KLH model tweeters are interchangeable. Does any one know for certain? Is there an alternate source than eBay? Are there any good new options? Thanks.
Thanks. All checked. It’s the little wire on the front that is the culprit and too precarious to repair.I believe the Five, Twelve, and Twenty Three share the same tweeter. There may be some differing opinions on that, but one of my Twenty Threes has an M12 stamped on its frame, and the thought is that that is Twelve tweeter.
Be sure to test the tweeter in question with a meter to assure that's the issue, it is just as likely that it's the 4uf capacitor that is the culprit.
Also those tweeters can sometimes be repaired, I've done several over the years so have others here.
Might be an easy repair. If you can see the break, chances are it'll solder together. Don't toss it, there's a limited supply!Thanks. All checked. It’s the little wire on the front that is the culprit and too precarious to repair.
I won’t toss it. Would a tweeter from a 17 work? Also 1.75”Might be an easy repair. If you can see the break, chances are it'll solder together. Don't toss it, there's a limited supply!
If the wires appear intact, try the meter at the solder spots where the straight portion of the wire is glued down. I had one that metered open and had a bad solder joint. Try that and post your result.
I tested it again from the solder point, no responce on the MM. I took a video of the test but I don’t see a way to upload that. I am not very technical so if I am doing something incorrectly please let me know the correct way to do this.
