tlann
Member
Hey everyone, I have a pair of Klipsch H700s that I absolutely love, but they’re the early versions where the grilles aren’t removable. And though my son is only two and a half weeks old, I’ve begun to realize that it won’t be that long before he’s grabbing and touching the speakers as he toddles by — a friend’s 11-month old did that recently, and I realized I’m going to have to figure some stuff out about my setup.
Luckily, I actually have some substitute non-original woofers that came loaded in the speakers when I bought them (as chronicled in this thread). I’ve since replaced those with some K-22s, but they honestly sounded pretty good, so I’m thinking of popping them back in so that, if worse comes to worst, the dust caps that get imprinted with the shape of a cute little toddler fist aren’t the Klipsch-branded woofers that I have come to value.
I’d also like to make some replacement grilles that I could put on during the toddler stage. That way, if anything gets damaged, the original / all-Klipsch speakers that I love will still be fine — I could just put the old grilles back on and swap the K-22s back in.
All that said, here is my question: does anyone know if removing the braces/frame pieces on the inside of an H700 would make it possible to then remove the entire front baffle? (Obviously the horns and woofer would also have to be removed.) My idea is to just remove the baffle (which the grille cloth is stapled to), make a new replacement baffle, and then make some replacement grilles.
Here is a picture of the inside, where you can see the small pieces of wood that seemingly are screwed into the backside of the baffle — is this the only thing holding the baffles in place? Is there any reason I should not unscrew these pieces?
Thanks for any wisdom/insight!
—Taylor
—Taylor
