Klipsch Heresys 1983?
fastss1987
Purchased some Klipsch Heresys from a friend for $200.00. They are in great condition. The serial #'s are 161Y111 and 161Y115. Going from an earlier post I believe they were manufactured in 1983 but that is about all that I could understand. Sorry. Any help would be greatly appreciated.
Klipsch Heresy 1983?
Thanks for the Info. but I'm still confused. I dont know what the 161 means before the Y. I believe they are 1983 manufacture but the codes in the post only show two numbers before the letter not three. The 161 has me confused. I guess I need someone to decode them for me. Sorry about being slow. Thanks.
My experience has been that it is normal to see two OR three digits before the letter. Don't know what, if anything, those digits code for.
You're not slow. Your dealing with the mind of PWK. ;-)
1. Letters that look like numbers (e.g. I, O, Q, V) were not used. "S" is frequently misread as a "5" and Y has been confused with an X on occasion.
2. July 29, 1955 was the last day for the four digit serials (i.e. 1811). After that the "number- letter-serial" system went into effect (2 August 1955). The first "number-letter-serial" speaker was produced on the 2nd of August 1955; that serial number was 1A812.
3. In the 1955-1983 serial method the first, or prefix "digit(s)" before the year letter represents the sequence of production for each 1000 units. The suffix digits after the letter code will always be three digits - 001 through 999. For example 1C999 would be the 999th unit built, and 2C999 would be the 1999th built in 1965 C = 1965).
4. These digits before & after the year code apply only to that type of speaker.
5. The year code letter only identifies the year in which that number occurred.
6. As an example, if you have a pair of Klipschorn's and one of the serial numbers is 15T252, then by 1979 there had been 14,151 Klipschorn's made (Klipschorn's made in 1946-1947 were serial numbered from 1 to 20, and in 1948 started with #121, skipping #21 through #120).
7. For a pair of 1979 La Scala's, with serial number 22T403, it means there were 21,403 La Scala's made to that point.
8. Another example: A pair of Belles from 1979 has the serial number 3T242 and 243. This means that in 1979 these Klipsch Belles, the 2,242nd & 2,243rd, were made.
YEAR OF MANUFACTURE (1955 THROUGH 1983 ONLY)
A = 1955-63* F = 1968 L = 1973 S = 1978
B = 1963-64* G = 1969 M = 1974 T = 1979
C = 1965 H = 1970 N = 1975 U = 1980
D = 1966 J = 1971 P = 1976 W = 1981
E = 1967 K = 1972 R = 1977 X = 1982
Y = 1983
