Klipsch Identifikation
Markkueh
I'm new to Klipsch speakers, saw these for sale locally. Nothing on them identifies a model except for a serial number on the back. Wondering if I should pick these up, price seemed okay but they are huge. Any help would be appreciated.
Look like Cornies (Cornwalls) to me.
Here's a 1974 Cornwall for comparison.
Rcornieoly
by Mark Hardy, on Flickr
dampedcornyhornies by Mark Hardy, on Flickr
(the 'Moretite' rope caulk on the MR horn was an attempt to deal with its aggravating resonances, FWIW)
Thanks for the reply
These look very similar, cabinets a bit rough. It appears base had some water damage but did not come up to Cabinet. Also one Tweeter is out, worth $500?
Run, don't walk, to pick them up at that price!!!! Tweeter can be sorted, most likely a new diaphragm or x-over capacitor (not expensive).
Those wii clean up nicely and you can easily double your money if you don’t care for them which is unlikely.
Thanks for the replies, picked them up yesterday. As I said the risers are pretty shot and the cabinet could use some work but inside they are original and clean. Orderd a new diaphragm for the Tweeter, hopefully that is the problem. Seems like a pretty straightforward repair.
Is there a way to identify the year of production based on the serial number stamped in the cabinet? The labels are not legible anymore. It came with K77, K-55-V, K33-B
if you have to replace a tweeter diaphragm you really should replace both so that the channels remain matched. Diaphragm profiles of original and new replacement diaphragms are not going to be identical. The old odd diaphragm can be kept as an emergency back up (if you ever need one). In the mean time do you have a meter to test the diaphragm itself for continuity? If not disconnect the tweeter leads at the crossover clean the contacts and re connect, sometimes when a driver goes out it is only a loose and oxidized connection. If this gets you back up and running clean all your contacts and save the new odd diaphragm as an emergency back up and keep your stock matching pair in service. Enjoy.
Looks like they are "I", which would be 1970. For $500 you did very well!! I agree with moray james, replace both tweeter diaphragms.
You can make risers quite easily. I just did the same for my CW II's.
There was no mention of Value here!
all righty then.
Great information here. They are actually T's, 1979.
Unfortunately I did not see the post above in time and only purchased one diaphragm. Nonetheless, I got the Tweeter working and the speakers sound really nice. Will pick up another diaphragm soon to match. Pretty stoked!
Now I am considering a recap and emailed Bob Crites with some questions since he seems to be the man. Mine have the type B crossover and I was told that the later B2 crossover would be an upgrade. Has anyone tried replacing a B with a B2 crossover? I think for now I will just buy the recap kit for the B and save some $ and enjoy.
