Considering the date of your post makes me wonder if the timing of the post had anything to do with the timing of the DW sales window.
I haven't heard the 5.5 but its admittedly lesser cousin, the KG 4.5, did not impress me greatly. Not familiar with tubes, but the 4.5s on solid state amps needed one with a decent amount of damping factor to come close to my other speakers.
Ouch.I had KG5.5's. Fun speakers. Like a more audiophile Cerwin Vega.
Isn't that the definition often given to CV's?frat house speakers.
Since the OP already has the 5.5's in hand he may want to try the Crites diaphragms, maybe upgrade the caps and replace the polyswitch with either new ones or a plain resistor.
Ouch.
I considered the 590's, but they're just too butt ugly. Though they do have a good reputation I'd say they have zero WAF (YWMV). For the right person I'm sure they are an excellent choice and would probably do fine with the OP's Scott. Actually saw a pair on Craig's list for $750 recently and was somewhat tempted. I guess I could order 590's, do my own direct comparison and send back the looser but wife would be very pissed if I wanted to keep both. Personally, besides appearance there were some other reasons I went for the ZU's stemming from curiosity of a full range driver mated with a super-tweeter, something I've run across before.
I did the Crites Ti diaphragm swap and it helped smooth out that slightly ragged top end nicely. I also had one poly switch fail and had both replaced. While the tech was in there, he swapped out some caps, too. This was early in my audio journey and I wasn't yet doing my own network mods/upgrades, so I'm not sure exactly what was done. It all resulted in a better version of the speaker than stock, though. A friend and I had just started dabbling in hifi around that time and he didn't much care for them in stock trim, but found them much more digestible after the mods. But it didn't take me long to progress to better speakers...Vandersteen, Magnepan, big, vintage Infinity, Altec...and that's why and when I realized the 5.5's were basically a fairly refined party speaker. And that's not a bad thing to me...just a category. Party speakers have their place and function and as long as you don't have unreasonable expectations and choose your music carefully, can provide some damn fun listening.
These KG 5.5s are my first taste of Klipsch. So far loads of fun and still enjoying my current set-up. As it happens with this hobby, I expect that I would eventually get the itch to try other options. When that happens, I prefer to get a new pair than go the route of the Crites upgrades. Should have saved up for a Heresy or a Forte by then. Or maybe try out the ZU's. You think it would be a big difference or step-up with Klipsch Heritage or DW's? Also interested on some of the speakers you have gone through, especially those Maggies, not sure if they are a good fit with my tube amps which barely put out 13wpc. BUT that would be a topic for another thread as I intend to not scratch that 'itch' for at least a while.
IME, Maggie's would want a more powerful tube amp, than 13 watts can deliver. I use a Cronus Magnum KT120 tube integrated, at 100 wpc, with 1.7i Maggies. For 75db max listening in a 400sf room, with headroom left. I have 6 and 7,5 watt SET tube amps I wouldn't even try.These KG 5.5s are my first taste of Klipsch. So far loads of fun and still enjoying my current set-up. As it happens with this hobby, I expect that I would eventually get the itch to try other options. When that happens, I prefer to get a new pair than go the route of the Crites upgrades. Should have saved up for a Heresy or a Forte by then. Or maybe try out the ZU's. You think it would be a big difference or step-up with Klipsch Heritage or DW's? Also interested on some of the speakers you have gone through, especially those Maggies, not sure if they are a good fit with my tube amps which barely put out 13wpc. BUT that would be a topic for another thread as I intend to not scratch that 'itch' for at least a while.
