Klipsch La Scala 68uf 150V caps - out if stock??
daveyh
I have looked all over and can not find any 68UF 150V caps for the crossovers. Parts Express is out of stock and will be until the middle of January, Searched he web and can not find any. Anyone have a source they can refer me to???
Try these guys. You can go up in voltage with no problem. 200v, 250v, 400v, etc. 250v is happy average now. Lots of options out there.
https://jemperformanceaudio.com/
I have used www.partsconnexion.com for years. They show to have the Solen in the size needed.
https://www.partsconnexion.com/SOLEN-51541_ss43615.html
ERSE has 68uf caps in 250v pulse x polypropylene. As mentioned you can increase the voltage without any problems, but most capacitors get physically bigger the higher the voltage & can be hard to place in tight quarters. ERSE are excellent caps & are what Crites uses for all their other components on their crossovers, Bob suggested them to me as a budget cap that measure very low ESR. They have fast/cheap shipping too. & since the factory caps are usually 10% tolerance or more, you can deviate a couple UF either way.
https://www.erseaudio.com/Products/PulseX250v
