A pair of Klipsch Quartets has just become available in my area. Would these be a good match with a refurbished Eico HF-81 amp? Currently running amp with a pair of Dynaco A-25's. Is $300 about right for these?
They are in Frankfort (CL). Never got a return e-mail so I assume they are gone.
Hey, and what do you mean about that "more speakers" crack...I only bought two pair this week!
That would be an understatement (IMNSHO). But the HF-81 would benefit from a rehab (again, IMNSHO).
The HF-81 uses ceramic coupling caps, so it's one vintage amp that does not a priori need new coupling caps. That said, I liked the sound of mine quite a bit better with 716P "Orange Drops" than the ceramics.
I'd try to be patient and hold out for some Cornwalls or LaScalas to match with that fine Eico amp. A pair may come up on Barter Town or I've seen Cornwalls on our local CL a couple times per year.
Ed, I ran my HF-81 on Forte's (slightly bigger brother to the Quartets) for a good while, and it was a beauteous thing. I wouldn't rule the Quartets out as very good candidates. Nor the Forte's, for that matter.
After the rehab I had wanted to use this as my main system. But along came a Pioneer SX-1280, so up to the master BR the Eico went. If and when I get a pair of efficient older speaks I imagine I'll switch things around.
