Klipsch RW 12d 120V Sub Power Problems
dysfunction
Hey,
I recently acquired this used sub, and have had problems getting power. Changed out the cord and fuse, and it did not help.
Took off the panel and was hoping it was a wire problem and was dumbfounded/horrified at what I found. Besides the obvious, there was what looked liked super glues as well in some spots. Any help would be appreciated!
Thanks!20191103_103906.jpg 20191103_103912.jpg 20191103_103932.jpg 20191103_103938.jpg 20191103_103945.jpg 20191103_103949.jpg 20191103_103955.jpg 20191103_103959.jpg 20191103_104004_001.jpg 20191103_104009.jpg
Edit: removed duplicate pictures and add this.
That adhesive is super common in plate amplifiers. Keeps things from rattling to pieces and prevents "chuffing" sounds that would happen if air was allowed to escape around those components. Looks 100% factory original to me (I had opened up one of those about a year ago to replace the display/controller so I'm familiar with what they look like).
Appreciate the heads up on it.
Any tips on solving the power problem? The small display won't turn on. It flickered once. Could it have to do with the burned adhesive in the 6th picture?
The power supply control board is toast. The amp will need to be rebuilt. The glue is factory and also what causes the problem.
