Brinkman
Analog loyalist
In the archives here at AK there have been threads regarding the use of an active crossover to bi-amp Klipsch speakers.
The pair I have are Klipsch Fortes. According to posts I've read, the lowpass filter slope of the crossover is 6dB/octave, and the bandpass and highpass slopes are 12dB/octave. In fact, I was surprised to discover how much sound the woofer contributes to what one hears from these speakers.
I recently purchased the two-way active crossover kit from audio-kits.com. In it's stock configuration it has eight 2nd order Linkwitz-Riley filters cascaded to form four 4th order (24dB/octave) L-R filters with Sallen-Key topology. However the designer, Ron Shaw, sent me modifications I could perform to change the kit to exactly match the crossover design of the Fortes. In other words, my active crossover now matches what the Klipsch engineers found to be the best "voicing" for the Forte.
A further benefit is that my woofer driver can now be fed directly by a 4-ohm output tap (solid state) and my mid/highs get fed off the 8-ohm taps of my modified ST70. The active crossover introduced no color and has an inaudible noise floor. And as was expected, my bass response and low-end presence has been vastly improved.
If any of you are interested in bi-amping but are having trouble finding an active crossover that matches your speaker crossovers, this is a very tweakable kit and Ron Shaw is incredibly accommodating. And if you have Fortes, he can provide you a crossover that is as close to the passive design as it gets.
Best.
Best.
