Hi All, Recently I was fortunate enough to find and purchase this tuner along with a KX-90 integrated amplifier. I am in the process of doing some restoration/preventive maintenance for both, but need some help due to my lack of experience with tube equipment in general. By the way, this is my first venture into the Fisher camp and I'm looking forward to listening to these 50 year old gems.
I've read up on the threads about this tuner and see that it is generally recommended that selenium rectifier be replaced with a silicon one. I saw that one from Radio Shack was recommended: #276-1181 rated at 8A/400V. I have one from Parts Express (050-030) rated at 6A/400v. Will this be sufficient and have a safe margin or should I get the one from R.S.?
When I do install the new one I see that it is suggested by most to use a resistor or diodes to drop the voltage down so that it will be at the level equivalent to what would have come from the selenium one. I see on the schematic that there should be 192V coming into the 4 x 40uf can capacitor after rectification. In a thread on Audio Asylum someone reported that they had 224V here after installing the silicon rectifier then used diodes to drop the voltage. Others mention using a 5w resistor (but that it gets fairly hot). What is the best course of action here? If the voltage is 224 what type(value) diode(s) or resistor would be a good starting point to to try to end up with 192v on the other side? I couldn't find any information with a recommendation as to a specific value resistor or type of diode(s). I hope to hear from those who've been down this road and hopefully it will help others in the future to have this more specific information. Thanks
. I turned it off immediately.
