ROFLMAO!!! OH YEAH, OJT & PQS!!! FUN FUN FUN!!
The getter is the silver, or black coating you see on most tubes. It's an indication that the vacuum is intact. When they vacuum it, and heat it up, the material the getter is made from FLASHES against the glass, and absorbs impurities. Depending on whether it flashes fast or slow will depend on the getter being silver or dark, like a black silver. If air gets in the tube, then the getter goes WHITE. NO GOOD! Also the getter is deposited either on the top or the side.
Your 7868 looks to have been FUBAR'ed. The Getter is on top as it is on all the other tubes shown. The "C" shape looks like a burn. Tube had a overheating episode, or had a runaway (china syndrome!). Hold on to it just as a curiosity and attention getter (this is what can happen...........).
Check the BIAS on the tubes also. Good call on the EH's. Good tube.
As for the rest of the tubes, have you checked them against another tester? It could be your tester tests that particular tube and gets a low reading. Some do that. My Eico 625 reads 12A*7's as 55-60 (weak to good) even tho a Hickok with a calibration tube tests them to 80+ on the meter. I'd check the tubes on another tester, and see if there is a calibration procedure for yours and have it checked.
Larry
