Koss HV/1LC restoration
I ended up breaking the small wires inside the voice coil. If you haven't already read my post from March 2, 2021, could you? I could use all the help I can if trying to repair this and save these headphones. I'm really wishing I had just replaced the foam pads and left everything else alone. :(
So, I ended up with a Koss HV/1 with a bad driver, and an HV/1A with a bad driver. Some differences of note:
The HV/1 has black plastic, and a shiny chrome ring between the ear cup halves. The head size adjusters are glued together. The drivers are bolted together, and have posts to which wires are clipped. The driver magnet is flat. The cups can be removed from the metal band without disassembly - the fingers just pull right out of the sides of the ear cups. There are metal tabs to keep the ear cups from rotating too far. There are strain relief tabs molded into the ear cups for the wires that go through the band.
The HV/1A has a slightly brown colored plastic and cord, and a matte silver ring between the ear cup halves. The head size adjusters are riveted together with two rivets. The drivers are melted together. They're inserted over plastic posts, and then a hot tool melts the post and the driver frame together. The driver magnet protrudes into the rounded area you can see on the ear cup side, with the mylar cone over top of it of course. (The HV/1 driver magnet is flat, and the rounded area is largely empty, just a little mylar bubble there). The cups cannot be removed from the band without disassembly -- there are metal retainers on the fingers that keep them from being pulled out of the drivers. There are plastic tabs to keep the ear pieces from rotating too far. The ear pieces on the HV/1A can rotate 90 degrees so that the headphones can lie relatively flat. (This can't be done with the HV/1s). There is no plastic strain relief molded into the ear cups. Oh and the drivers don't have posts, they've got standard solder pads.
Sound-wise, I cannot tell any difference between the HV/1 and HV/1A drivers. I had a bad driver in each, so I combined them into one good headphone, and with a mono source both sides sound identical. So that's nice. The drivers in both of these suffer from the mylar cone coming apart from the driver itself. There is a sealing ring, and the glue just dries out. This will give you a buzz or a lack of highs. Be careful when disassembling, as the mylar and voice coil will tend to stick in the ear cup, and the magnet back will fall right off, breaking the voice coil wires. I could have repaired the one if that hadn't happened to me. The HV/1A drivers cannot be repaired without a lot of work and care. You'll need a hobby saw to cut them apart, and then you'll need to drill and tap for screws to reassemble it. (or just use glue, but it would be nice to leave these as repairable in the future).
Neither of the HV headphones I own have volume potentiometers. I'm not sure if that was an option for a different year, a different model, or for the International market.
Either one of these are good headphones. The HV/1s have more strain relief and more shiny parts. The drivers are more easily repaired. The HV/1As can lie flat, and have head-adjusters that you can disassemble and repair and re-rivet. (In both cases, the HV/1s have broken plastic tabs in the head adjusters, making them loose and floppy. This can be repaired with a strong closed-cell foam, like a piece of a Mr. Clean magic eraser, glued into the inside of the adjuster to make it have some tension). In all cases, every bit of cloth and foam inside these headphones was rotted away, and needed to be replaced.
These look great with blue and red scrim cloth -- I just used speaker grill cloth, and a little contact adhesive, then some foam behind the cloth.
View attachment 850592 View attachment 850593
Charles.
So what happens now?
There is a pair on eBay you could use as parts $35
Thanks Mike, I see that.
I sent him a message asking if he would ship to Canada - as I can't get across the US border to pick up packages. A lot of sellers will not do it.
Also, the ones listed are HV1/LC's. Mine are HV1. Are the LCs the ones with the different voice coil driver? It may be completely different, in sound and in structure.
I see there is another pair of HV1's in Maryland with the jack cut off but they look absolutely nasty. I doubt the insides look any better than the exterior.
Having a similar issue with the incredibly fine coil wires broken on my vintage Sennheiser HD424’s. If i learn anything useful i will post it (after a chat w the company’s tech folks). Probably you have already found a fix or trashed them by now, but...
BTW, there supposedly was an ‘improvement’ in the HV1 series drivers and I have both a HV-1A and a HV-1LC (with volume pots on L&R ear cups) and one of them has the ‘New Decilite Drivers’ inside (though at the moment i cant recall which) so, yeah, there MIGHT be a difference if you mixed and matched, but i doubt if it amounts to much.
I have had lord knows how many headphones over the years, Koss, Sennheiser, AKG, AudioTechnica, Pioneers, and a bunch more I’ve forgotten, but i really liked the HV’s sound even if they weren’t the flattest response cans — for rock they were great and the old foam cushions were comfy enough and somehow kept my ears feeling less sweaty-overheated.
I am tempted to go up the attic and pull those bad boys out to put ‘em to good use again — hopefully they still work though i bet that old foam is shot by now and somehow i doubt if Koss has any more foamy ones lying around at this point, in 2021. :(
Hi there! It sounds like you've had a lot of experience with headphones. Other than these ones and the small ones or Bluetooth buds I have for my portable (phone/ipod) music I don't use headphones that often. I prefer to crank the loudspeakers.
I took my HV1s to a local vintage audio shop that does sales and repairs and they have a tech that specializes in speaker repair. I was willing to pay a couple hundred $ but unfortunately they could not be repaired. Voice coils can be rebuilt/restrung but in this case the problem was with the bonding to the clear backing that would have been destroyed in the process and would have resulted in the speaker not working.
I will post some photos and an update soon. I don't want someone to make the same mistake as I did thinking that the voice coil assembly would remain intact after separating the black plastic. If I had better information at the outset - like better photographs - I would have left it alone and be enjoying them now.
I am keeping my eyes open on Ebay for a pair with a dead side. It has to be an HV1. The HV-1A is the updated driver. I would need to replace both sides in that case. I'm sure that eventually, with patience, I will find one. I'm in Canada and many Ebay sellers will not ship here (so I can't even bid) but as soon as the border reopens I will be able to ship to Blaine, Washington and that should open up more options.
I have two sets of foam pads which I bought from Koss in 2017. I think you can still order them but if you are stuck and want the real OE, I can send you a set. There are lots of aftermarket ones on Ebay and Amazon. Many are vinyl covered foam but there are some bare ones available too. I like the foam ones too for the same reasons you do. They don't hold the sound in very well though so my family usually hears everything I do if they are in the same room.
Stay tuned. Cheers!
Stay tuned. Cheers!
Hello KRJ-
Yes, 2020 hindsight, i have that too! I probably wont be able to fix the Sennheiser I clumsily disassembled— and i was SO CLOSE to successfully completing the surgery and cleanup of the icky-sticky residue of the thoroughly decomposed foam pads which sit right on top of the driver diaphragm face! Oh well, another case of not taking the time to ‘measure twice, cut once’ and also a sign of my less-than-stellar eyesight in these ‘latter years’, haha.
So...back to the KOSS:
I would love to get those pads you have, and if i can help you with a ‘trans-shipment’ of some item that is a must-have from a seller who won’t ship to Canada (stinkers!) i could do that too (i.e., ship it to me here in San Diego and i will forward-ship to you up north — a cumbersome arrangement but maybe worth it if you can find an ideal item you really want. Headphones are probably not too much $ to ship SoCal-Canada i reckon (?).
If i stumble upon a HV-1 down here i will let you know.
Best Regards,
Dave in San Diego
They do have replacement foam ear pads, I just got mine from Koss this week, cost $5 plus free shipping in USA.
Not anymore. In late 2023 I asked for info, and Koss customer support said they are NLA. I asked for technical details on the foam material and they refused.
I will describe my experiments and results in the "KOSS HV High Velocity Series" thread.
Short answer: (1) knockoff Grado size G cushions give a good approximation to the original fit and sound (but not appearance) of the HV/X, HV-Pro, and Radio Shack Pro-60. (2) Shark(tm) vacuum cleaner air filters for model NV42 and the Rotator series may be modifiable into acceptable cushions for the HV/1 and HV/1A.
