c.coyle
Fighting the Dunning-Kruger effect.
I picked up a Kenwood KR-4070 receiver. All inputs and outputs work fine, except for FM. All controls, switches, and jacks have been cleaned. I haven't found anything open, broken, burnt, or bulging.
On FM, when I tune across the dial and hit a strong local station that I know is broadcasting stereo, both meters deflect, but I get no audio and no stereo light. Instead, I get intermittent, volume-dependent, metallic crackling (headphones, haven't hooked up speakers yet), anywhere on the dial, signal or no. Otherwise, silence. I can't hear any actual station or get the stereo light, no matter how strong the signal.
1. There are 2 2SA640 PNP's near the MPX chip. That along with the crackling led me to replace them with 2SA970BL's, but no change.
2. I deoxited VR1, the VCO pot, which looked a little corroded. No difference.
3. I went through the signal path step by step with a signal tracer, and it traces all the way from antenna terminal to speaker output.
I don't like replacing part after part on a hunch. Something tells me it's the MPX chip or something in the detector circuitry upstream from it. I am, unfortunately, scopeless.
Thoughts or suggestions?
EDIT: Added schematic clip.
