Kr-4200
niejls
Kr-4200 - Cardboard?
Hi,
I've recently bought a Kenwood KR-4200 that I'm planning to repair. Does anyone have a service manual for this?
More specific, I'm looking for the idling current adjustment and some good schematics. I can only find a real poor scan of this.
Thanks in advance,
Niels
Thanks for the bias info. This scheme indeed isnt that bad, once printed...
I've just opened it up and found this:
Some orange greasy stuff on the pots.
Anyone seen this before?
Just clean it off? Or is there a cause/reason for this?
The rest of the inside seems ok at first sight.
I cleaned of the orange stuff off and cleaned the contacts if the pots with deoxit. They look a lot better...
The entire PCB wa soaked with grease. So it got a good clean as well.
When pulling back the tone-PCB I noticed there was some sort of cardboard behind it. Again, soaked with grease.
Does it serve any purpose? Can it be replaced with ordenary cardboard, it looks/feels like it? Or is it something else?
Thanks!
It's been more than a year since I've had the time to work on my KR-4200, but now I'm planning to finish it... :)
I'm currently looking to order the replacement caps. But I need some help on finding a replacement for the largest ELNA caps.
There are two ELNA CE-W 3300µF 35V caps in this unit. What would be a good replacement?
attachment.php
It would also be nice if the diameter of the new cap would be about 25mm, so it would fit the mounting claps (see picture).
Thanks!
Thanks, EchoWars.
I've noticed that both the capacitance and voltage of this cap exceed the values of the original. I can understand that the voltage isn't a problem. But should the capacitance not be the same?
The datasheet of the series shows that 3300µF, 35V caps exist, but these aren't available on Digikey.
Welcome to AK shair00 :)
You will probably have better luck if you start your own thread instead of attaching your project onto an old thread.
