benjaminlee
I had some issues with transistor noise on one channel, which I fixed, but some similar issues appeared on the other channel. I decided to go ahead and replace everything on the amp board with a repair kit off of eBay; essentially everything but the resistors, in hopes of future proofing a bit. I also replaced the outputs in the faulty channel to be safe.
I took around 7 hours to do this repair, making sure I followed the included instructions carefully, replacing both channels of a given component before moving on to the next, and keeping the old components sorted, which I still have. I powered it on after finishing, and it left protection mode, but only the right channel seems to be working.
There is very faint noise at higher volumes but I assume that is some sort of bleed. I was fairly tired at this point so I just ran a few tests, it seems like the voltage across the transistors on the working channel was ~6v not long after powering off, while the non working channel’s shows close to 0v. Tried different speaker groups/different speakers, same issue.
I reflowed the joints on the working channel, and checked thoroughly that the orientation of components was correct. I will send pictures when I get a chance. If you have any advice or suggestions let me know! My current thought is just putting the old components back on that channel one by one until it comes back to life.
