Great. How much power do you get with 372Vdc at the plates?
I have 360VDC at 6CA7 plates, and only get 3.5Wrms per channel.
Will try to use SS rectification and change 10uF filter cap to 22uF so I can increase B+ a little bit.
This design requires a preamp to reach full power. It's one of the reasons I ended up going with a different driver tube, with a higher amplification factor, on my next build. Mark talks about this amp needing the additional drive to reach full power in the videos. And by "360 at the plate", are you talking about the voltage across the tube or just measuring the V at the plate pin referenced to ground?
