KX-1030 a keeper?
Flaminroids
I acquired a Kenwood-Trio system not too long ago and the tape deck that came with it is a Kenwood KX-1030. Now the lights and meters all work, but the belts are done and all of them need to be replaced. It is a triple head so I thought it might be worth fixing but I never hear anybody talking about Kenwood tape decks so I thought I would check to see if this one was worth the $19 to fix.
It will likely also need new idler tires (2) and a pinch roller. Those should be available, but will be difficult to find and to install, so be forewarned. A large time commitment overall.
yes its a keeper, theres alot of better decks, and kenwood made 2 better models that im aware of, the 2060, and the 1060, but the 1030 was at one time their totl deck. and they do sound very good for both playback and recording. I have been looking for a Kenwood 1030 to restore for a while.
That's because they only made 2 or 3 decks that are any good and this is one of them! The 1060 has a cool bias oscillator in it that alternates between 400Hz and 10KHz and you record the tones and adjust the bias so they play back at equal levels. The 1030 is a very nice deck, too. Make sure you replace the pinch roller if it is shiny. It should be dull black.
Oh nice. I was hoping it would be worth fixing because it matches my tuner and amp. The reason I ask is because I've picked up a few tape decks in the past that had broken belts and some research showed that they weren't very good decks to begin with. I picked up a nice looking Yamaha deck that needed belts but it turned out to be low end junk. Well, this should be fun......
A keeper. Among the very good things about it: the ferrite heads, which outlast conventional permalloy heads several times over.
It is definitely worth fixing! I have one and thanks to AK..,i found that you only need to remove 1 screw to remove and replace the main belt. The sound..? The best cassette by far that I have had. There are better to be sure, but the sound for me,is quality!
Great! I look forward to hearing this deck then. I ordered the parts and I will let you all know how it turns out!
Which screw is it? I have 2 KX-1030 and one KX-1003 that need belts changed.
I did a google search on .."kenwood kx-1030" and the pull down offered "kenwood kx-1030 belts", I selected that one and about the fourth entry on the first page shows an AK page w/ photos..that's the one I used. I would link it to this response but I don't know how!!
