Ftlbs
I picked up a clean KX-800u a awhile back and decided to look at it while waiting for parts for other projects. It would play for a few seconds then shut off. Same with FF and RW. I replaced both belts and cleaned the goo from the old belts. Reassembled and unfortunately does the same thing. If you hold the play button down it will play and sounds good. The counter works fine. I'm not sure what to check on this. Thanks for any guidance. Sorry for the duplicate post. Original i accidentally put Kf instead of KX and didn't see any way to fix it.
