L19/4301 Cabinet Build - Need Specs
sabrefencer
AK Subscriber
I have a nice pair of 116A woofers and want to build a set of L-19/4301 clones. I have overall dimensions for each - they are slightly different, but internal volume is similar (1.1 cu ft for L19, and 1.06 cu ft for 4301). What I do not have is a layout of the baffle with dimensions for either variation. I would prefer to stick to the L19 spec, so if anyone has a pair of L19s and is willing to provide dimensions or can point me to a source that would be very helpful. The overall dimensions I have for the front panel is 21"x13". Assuming this is correct as a baseline, I need the following dimensions (to nearest 1/16" or mm): Side of cabinet to edge of woofer (woofer appears to be centered L/R on baffle), Bottom of cabinet to bottom edge of woofer. Side of cabinet to edge of port, bottom of cabinet to edge of port, diameter of port opening, depth of port, if port is straight tube or curved. Top of cabinet to CENTER of tweeter, Side of cabinet to CENTER of tweeter (tweeter is offset to one side so need dimension from each side to CENTER of tweeter). The reason I want dimensions to center of tweeter, is that I may not use the LE26 and can then index off the center rather than the side.
For crossovers, I plan on sourcing a used pair of factory units and possibly refreshing caps.
Thank you in advance, Gary
L19:
  • Overall dimensions: 21" x 13"
  • Side of cabinet to edge of woofer: 2 3/16"
  • Bottom of cabinet to bottom edge of woofer: 3 3/4"
  • Side of cabinet to edge of port: 2"
  • Bottom of cabinet to edge of port: 2"
  • Diameter of port opening: 2" ID
  • Depth of port: 5 1/4"
  • If port is straight tube or curved: Straight
  • Top of cabinet to CENTER of tweeter: 5 1/2"
  • Side of cabinet to CENTER of tweeter: 5 1/2"
This is perfect. Thanks Zonker.
Gary
Since right now I still need x-overs and tweeter. Complete L19s and, L26s seem to be fetching stupid money, and decent ones don't come up too often. May be I will try barter town. I was eyeing a set of complete speakers on the Bay. But they are in pretty ratty condition. If I can get more parts reasonably, i will go for the build. Thanks again for the dimensions.
Might as well build your own crossovers...they are pretty simple and probably cheaper than buying used before you replace anything.
Good luck!
