Nostoppin1
Hello all, this is my first post here. I love this website and, having found myself here multiple times as a result of internet searches, figured it was time to join in.
I'm looking for wisdom on the DCR of my drivers and recommendations for which caps to choose for replacements.
I just picked up a pair of L20t3's to use one as a center channel for my L100T's. Planning to recap the unused speaker, I removed the 035TiA and 115H-1 to more easily take the X-over out.
As a lark, I put the ohm meter on the drivers and I'm a bit bummed out. The DCR min-max on the 35Tia is 3.5-4.2 ohms, and mine is 4.1. Right on the edge.
The 115H-1 min-max is 3.8-4.6 ohms, while mine is 4.9. I replaced the batteries in my meter and retested, seeing a .1 ohm drop to 4.8. Still out of range.
How bad is this? What makes driver resistance change over time? Would it mean using different cap values for the new ones?
as far as caps: the little .01µF ones. My friend google says these are bypass caps and should be film. Would you agree? what tolerance?
The 100µF electrolytic: replace with film? would it matter which type of film - polypropylene? there's so many types!
The big yellow one: I get the value, 4 ohm. I get the K being +/- 10%. it's the CEC that confuses me. is it ceramic? internet searches don't seem to have the answer, or I'm not asking the correct questions.
Thank you for your time! Peace!
