papagiorgio
Hi, I just pulled a Lafayette LR-3500 from someone's trash and fired it up. At first there was no sound, but that seemed to resolve itself after a few power cycles. I think the protection relay was stuck from lack of use and worked itself free. The receiver now seems to be mostly working (I am surprised at how good the AM radio sounds, using the stock antenna), but the unit still has a few issues. The most significant is that there is no sound (well actually a tiny bit of sound when volume is set really high) when the tone controls are in play. Sound is fine when switch is in "flat" mode, but no sound in "Tone" mode. Both L&R channels are lost, which is interesting because the tone systems seem to be independent for each channel. I was therefore suspecting a power-supply problem since that could affect both channels. I measured the voltages on the 7xx board - some of the readings I got were:
- Pin 3 ("+B"): -40v measured; schematic says -38.1v
- Pin 4 ("-B"): +39.9v measured; schematic says +38.2v
- Pin 5 ("+35v"): +18.6v measured; schematic say +31.8v
- Pin 6 ("+13v"): 11.5v measured; schematic says +13v
The reading for the "+35v" line seems troublesome at only +18.6v. I started probing around Q701, which seems to be most-directly in control of this supply line. The capacitors checked out ok with my ESR, and the resistors where in range of their markings. Having said that, R702 is marked on the schematic I have (which is difficult to read) as 22 ohms, whereas what is installed is 270 ohms (see picture). There may have been some rework done in the area, but the transistors look original. I am wondering if there was any update to the schematic which changed R702 to be 270 ohms, or if this is a mistake that I should correct. I am reluctant simply to swap out the resistor as I don't want to blow the transistor. Can anyone tell me the value of R702 as installed in your LR-3500?
Update: I tested the Tone/Flat switch and it appears to be working normally.
Second Update: I am now suspecting C521. It is hard to get to, but is showing some brown leakage at the bottom...
I have a few other questions
- does anyone have a good-quality schematic scan, user manual, and/or service manual for the LR-3500? It looks like hifiengine has some manuals, but of course I can't register anymore to download the files. I have some poor-quality split-page schematic scans that I got from radiomuseum.org. I see this question has been asked several times before, but I haven't seen an answer...
- does anyone have other theories as to why I lose all sound in "tone" mode? What common points of failure could there be that would impact both channels? The High Filter and Loudness functions are working. The problem occurs with all inputs and all speaker combinations (headphones, mains, etc.).
- on a different note, several of the lamps are out, including the one for the signal meter, and also at least one backlighting the frequency display. I don't see any part numbers for these lamps on the schematic - does anyone have part numbers for these lamps? I would like to avoid having to take the front apart just to get the numbers.
Thanks for any help.
-Paul
-Paul
