lapping tape heads
I will post the polishing films tomorrow.
BTW the manufactures, measure the head inductance to check that they do not over polish a head and open up the pole piece gap. I do not know the spec for your heads
Don
Well, the heads still work. They're back in the machine that I'm listening to some Neil Young on right now. :D :music:
For tape heads contact :
THE MAGNETIC HEAD COMPANY
www.magneticheadcompany.com
They have an online cross ref/catalog just loaded with head info.
You,ll find specs for almost any head.
As I recall over polishing causes high freq loss.
Glad yours work OK.
Let us know how the FO polishing film ( wet ) works out
Don
How do you know the size of the head gap? I would think taking off material would increase the gap?
You did a very nice job of keeping the contour of the head.
Ron
Don
The films arrived today! I'll probably pull the heads later this evening for some final polishing, and let you know how things turn out. I'll try to take some photos too.
:music:
Just gone done polishing the heads. They gleam like mirrors now! :D
Time for some pictures!
:music:
:thmbsp:They look so good you wont run to run a tape over them!- after all a tape is nasty rust stuck to plastic and dragged across at 30 IPS. Bit like taking a restored car out in the rain on the highway...
Well, my machine only runs at 7.5 and 15 IPS. ;) :D
:music:
What film did you use?
I first used the dark grey square, 15u, then the light grey square of 5u.
Then I tried the disk, and it's CERTAINLY not 3u or 5u like the note says, because the shine went back to the duller finish similar to the 15u.
So I went back to the 5u, and the finish it produces is what you see in the photos. ;)
:music:
Orcinus
They look great
I wonder if 5u vs 15u vs 600 g ... can you hear a diff ?
Glad the films worked . Some films are aluminum oxide , silicia carbide , diamond , the 5 & 15 are alum oxide.
Don
Nortronics has a PDF on head lapping.
recordist.com/ampex/docs/repairtips/heads/nortronics.pdf
I have a bro.-in-law that works with fiber optic cable who can lend me his polishing kit.
Think I'll give it a whirl!
Rich
Ron
I Googled this up a while back and apparently heads run a uniform gap quite deep before it widens, so unless your looking at huge gaps all the lapping does is restore the contour to the supporting material.
You can also tell when you've eaten through too much head material, as the gap will "open" and you'll see a black line appear in the head. Once you see this line, it's game over. The head -IS- garbage.
Care must be taken to get the contour correct, and the face square (parallel to the tape path). If not, the tape will not lay across the head properly and performance will suffer.
Inductance should be measured prior to relapping. This measurement could indicate the the head is already gone. Also, the depth of the gap/groove should be gauged, This too could indicate that the head is already toast. If relapping proceeds, the resulting inductance should be compared with the initial readings. When the gap has begun to open up, the inductance drops off precipitously. There isn't too much inductance to start with, so accurate and precise measurement is needed.
Warning, professional experience is not to be dismissed in this process. That is so one knows what the inductance and safe depth should be. This is also so that specialized equipment will be available. some of these heads are made of unobtainium. We do not want to ruin them due to lack of experience.
Enjoy,
Rich P
I have lapped a few heads as well. At the point where I have nothing to loose, what the heck. All results were excellent.
I also lapped a set of completely trashed Revox heads. To my amazement, I got away with it. It was THAT or a ton of money for new one's. The gamble paid off, since I stole a buy it now auction for a record and playback pair NIB for.....
$70. :yikes::yikes: Damn near used 2 mice to click the buy it now button!
Yes, they were indeed brand new. I still have not needed to use them.
