flavio81
Turntable technician
Flavio, I respect your contributions to the science of sound reproduction but I do take exception to your insisting I am a gullible fool.
I didn't mean to call you a fool. I apologize.
A couple of questions for the long-time Lasters here...
Do you use the record preservative on ALL your records? I have some records that I love despite their so-so condition. I don't know if I should "waste" the preservative on these or on records that I play very rarely. I don't know if I'd be compromising the effectiveness of the Stylast treatment by playing untreated records. Let's assume that I restricted the Last preservative treatment to ~75% of my records. Would playing ~25% untreated records reduce the life extension properties of the Stylast?
What's your stylus treatment method? Do you use the Last cleaner and then Stylast before every side? Do you look at the stylus and skip cleaning it for a side or two if it looks clean?
Thanks!
Thanks Mark. What you say all makes sense. I hope Sparky will chime in with his thoughts as well.
I am pretty fastidious when it comes to record cleanliness. There's always room for improvement, but I think I have that part of it covered well enough. I've treated perhaps 20 records so far, and I haven't made that much of a dent in the $40 bottle. I'd estimate that the bottle could treat about 150 records. That's actually cheaper than the MoFi innersleeves I use after cleaning a disc. I've got about 1200 records I guess, probably ~100 get played often, 400 or so get played occasionally, 400 or so get played rarely and the rest get played never and should be passed along. Now that I've done the math on the cost per disc, I think I'll just treat everything except the ones that are already fairly worn AND don't get played very often. I'm curious what Sparky has to say....
Thanks Sparky. I should've thought of that in the first place! Yes, the first post answered my questions.
Take it from good authority, that I shared in an earlier post. "LAST" is chemically a snake oil, a simple placebo. It evaporates harmlessly into the air or at best leaves a coating on your record. I would say that would have a negative effect on the sound. As users have pointed it out, "it took the harshness away", meaning it dulled the sound by leaving a coating on the vinyl. Read about it here:
http://en.wikipedia.org/wiki/Polytetrafluoroethylene
...or at best leaves a coating on your record. I would say that would have a negative effect on the sound.
Fomblin® Functionals PFPEs can react with conventional polymeric materials with the aim to impart to them the specific properties of the perfluoropolyether chain such as:
Chemical resistance
Low surface energy
Water and oil repellency
Anti-sticking properties
Low refractive index
Boundary lubrication
I haven't heard that Last 5 or the record preservative 2 contains lubricant.
Call the Last Factory maybe that'll help.
Patent Composition for protecting vinyl records
Scuzzer, I know you are skeptical of claims that have no supportable scientific basis.
Reading your posts I'm not really sure what your opinion is on LAST....do you think it's a product that's worthy of an open mind, or would you dismiss it as snake oil?
