quiet
Addicted Member
The 75 Dart is a 318 two barrel, auto, p/s, p/b, a/c, single exhaust, no rust, clean inside. The car has OK power for traffic or the hwy. Zero to 60, about 10 seconds. I already replaced the fuel tank, fill pipe, fuel sender, fuel pump, all fuel lines, starter, tires, battery, 4 shocks. It's motoring up and down the interstate at 80 very good now.
It needs,
Total brake job, all of it, every last bit. They work good, but it's all older than dirt.
Ignition attention.
Carb.
Exhaust.
Air conditioner fix. It's complete.
Two sway bars.
Now, here's the question. What carb to use with an air gap dual plane 4-barrel manifold, 2 or 2 1/2-inch dual exhaust, 360 heads, and stock cam? The power curve is just fine. I need guidance on this carb thing please.
This is going to cleanup fine and be a fun little car. It will be about 4k all in.
The 64 New Yorker is a 413 ten to one 4 barrel, auto, p/s, p/b, a/c, posi-rear, no rust, clean inside. It has a lot more motor than it needs. It's a tire burner, I like it. Zero to 60, about 7 seconds. A 361 low compression 2 barrel would have been just fine. It too is running the interstate really good at 80 plus. It came to me with new tires and battery.
And it needs,
Proper seat belts.
Proper seats with head restraints.
Complete total brake job. They work good, but old.
Single to twin master cylinder conversion. The shoes are 11x3. And it stops yesterday. So they stay, no conversion there.
Shocks.
The good working Carter carb cleaned.
Proper tune-up, and points to electronic conversion.
Outer axle bearing. Noise.
A/C fixed. It's complete.
This car has some really long legs on the interstate. It will come in at about 5k all done, no new paint. Constant wax to keep the rain from washing off the rest of the paint.
The question on this car is, why do the good condition and proper fitting hub caps refuse to stay on the correct and good condition wheels?
Maybe you like old cars or maybe you don't. So.
