I bought a pair of Leak Sandwich speakers off CL. These have the 13" woofers. One has a slight rattle and I think it needs to be rotated 180. I removed the screws but I couldn't get it to turn. Is there a special trick to rotating these woofers?
Did the rotation alone sort out the problem or did you have to do further work?Well, I'll be damned! You're right. I undid the screw and then I could rotate the woofer. Thanks a lot. I never would have figured that out by myself.
It may be too late to rotate the woofers - I've had two pairs of Leaks where the woofer had sagged on the suspension so much that they could not be restored without removing the doped cloth suspension (which was difficult to do without damaging them), and I couldn't find a source for replacements. I still have a couple of the woofers and may see what happens if I use foam suspensions on them.
