RuSsMaN
Pudknocker
Here's another one you don't see everyday, a Leak Stereo 20. Neat little British amp, brought up to todays standards. Sounds amazing.
Push pull 6BQ5 / EL84 (Mullard ProComm), 10wpc. 5AR4 rectifier, and 12AX7 (Telefunken) on the front end.
Upgraded with Sonicaps in the signal path, Cardas rca inputs, Cardas milled solid copper binding posts, and a power on / off switch was added to the rear. The stock power socket was retained, but the stock cord upgraded with the same termination to help maintain it's original appearance.
4/8/16 ohm taps adjustable on top of the output trannies via a simple jumper, as is votlage setting on the power tranny.
Cheers,
Russ
Cheers,
Russ
