audioaaron
Hi all,
A good mate of mine was cleaning out the projection booth of an old theatre when he came across a Leak Stereo 60 Amp that was marked for the trash. He rang me to see if I was interested in it before he was about to toss it into the rubbish.... So I now have a Stereo 60 sitting on my work bench.
I've read a lot of posts about the Leak amps these amps on the web but not as much on the Leak 60 compared to the 20's and 50's although I believe the 60 to be similar to the 50.
I’m an electronic tech by trade and have worked in the field the last 10 years (mostly with solid state equipment) so I can work my way around a schematic. I’ve always loved vintage audio but don’t have as much experience with valve technology. I’m thinking about restoring this amp to use it as part of my home stereo system as reviews I’ve read about these amps seem quite exciting. Has anyone restored a Leak 60 or similar valve amp and would have any tips or tricks with what I could do to bring out the best in it? I’ve read both the pros and cons that oil filled caps are the way to go etc… being a valve amp I’m not entirely sure what the best thing would be to do. Any ideas? I plan to replace all the caps and resistors and have all the audio valves for this amp. I’ve been buying my replacement 600v + cap’s from eBay as they are hard to source here in Australia. Can anyone recommend an online store which is good to purchasing replacement parts for these sorts of things?
Many thanks all, any info would be greatly received.
I've attached some images of the amp.
