I picked up this Leak Through Line Tuner in a junk shop last week for pennies, I have read about it on the web and it seems a good one. Its in good working order but I know that I will have to do work on it to bring it back to great condition. I tested the valves (tubes) and they are all low so I have managed to get the seven replacements off the web for good money, they are all Mullard nos. I have the circuit diagrams and I have the components lists. I have refurbed much solid state but never a tuner or indeed any tube gear but have researched on this forum and have a fair idea what has to be done, I have been inside and checked most of the resistors and a lot of them are well out of spec.
I think I am correct is saying that I should only change some of the caps? Should I re-tube before the component change or after? I have a local dealer who will align the tuner for me after the work is done.
I want to add a stereo decoder to it, it has the multiplex output, and I can get the original Leak decoder. or a new built one. Obviously the Leak decoder is very old (1962) and quite basic. the new built one is the best available in the UK, will adding solid state to this valve tuner take away the sweet sounds the tubes produce? My system is all valve.
Any help or comments would be appreciated.
