Originally posted by rhinofly
Well I am confused. It sounds like the only way to identify a bad item (one that isnt in some way visually obvious) is to measure voltages on the board and compare to whats on the schematic. Then trace down anomolous measurements by desoldering suspect items and testing them off board?
Sorry...I am new to this. I understand electrical theory quite well...but have almost no practical experience troubleshooting and fixing complex electronics like audio gear.
That is almost exactly how one goes about it. One missing step in the process is understanding first how the circuit is suppost to work and then making measurements to isolate the stages between the functioning ones and the defective one. One has to have an expectation of what to expect to have a good chance of finding a measurement that is off. Most stages have a signal goes in and a goes out along with DC bias and supply requirements. Stereo stuff can be a lot easier in that you probably have a good channel to compare measurements with. Typically the DC power circuitry is the only thing shared.
Troubleshooting is fast becoming a lost art as most new equipment is designed for module removal and replacement or to be non repairable in the first place. Component level troubleshoot requires a lot of training and experiance and not everyone enjoys the challenge. Repairing electronic problems is pretty trival really, just replace the bad component(s). Knowing which component(s) need to be replaced, now that is the trick.
I have always enjoyed the challenge and have had a rewarding work history doing just that. Not everyone's head is 'wired' right to be real effective at it. A mental trick I have used often is to 'become the circuit', that is try and assume your are that circuit and figure out what you need to work. Do I have a DC current suppy? Do I have a output path, etc.
Some useful tips?
Spend plenty of time first accurately defining the symptoms of the problem. If more then one symptom, which is the more basic symptom.
Assume there is only one problem, and repair it one problem at a time.
Assume nothing is good, test it to prove it's not bad. I once had a 5 amp fuse that had somehow developed like 10 ohms of internal resistance! Now that one had me for awhile...
I still cring when I read sometimes where someone is going to go in and replace every cap and resistor in a device. That is a very ineffective way of repair in that it takes lots of time and money and one seldom learns anything from the experiance.
OK, ready? go find something broken and start troubleshooting it :uzi: :uzi:
Lefty
