Learning about cross over restoration.
Ishmael
I have enjoyed refoaming several speakers as well as restoring their cabinets and speaker grills (in a past life I built some funiture). However, I have usually let others do the cross over restoration as I have no experience/knowledge about the electronics (cross over). Looking at most cross overs it seems like a project I could take on. Are there some basic books on cross overs, electronic schematics, and what the various parts of a cross over do/what the values for those parts mean that you would recommend? What are the basic tools needed to take this next step of rebuilding a cross over, any recommendations? I have searched past threads and they seem mostly to be focused on the rebuild of a particular speaker's cross-over, as opposed to the more general basic level of understanding I am looking for, e.g., what does a capacitor/inductor, etc. do, what does their labeling mean, how do you follow the signal path through the cross-over/schematic? How do you test for what isn't working in the cross over? Any help will be appreciated as I would like to try and learn how to do this. Then mayber taking the next step of looking into a receiver and taking on a re-cap project. Thanks.
If you can read the capacitor values on the crossover, you already have half your battle won for you. Simply select the same value capacitor from a vendor who sells new ones. Erse Audio, Parts Express, Madisound, all stock replacement capacitors. More often than not, they are simply hot-melt glued to the back of the cabinet, so you can remove them and fix your new ones there the same way. Obviously you'll need a soldering iron, but you don't have to spend a lot of money for this, especially if you are only doing crossovers. Film capacitors are often a good upgrade over electrolytics in crossovers, but if you're on a budget, sometimes a large film cap can cost more than the speakers in question.
Hope this helps,
Lee.
Thanks lee, in looking through the web I see that there are a lot of different makes/kinds of soldering irons, what would you recommend? I have also heard of something that sucks up the old solder, is that a good tool to have and if so what would you recommend? I have found a lot of tutorials on youtube for soldering which I will watch and then do. My plan is to take my modest work bench realistic speakers and use them to practice on, swapping in better caps.
