Well, I went a bit crazy and picked up a few of the Technics Linear Trackers - the first one I ordered, the guy got sick and didn't ship it until really late, so I just got it today. But, by then I'd already found a couple more that were pretty well priced, so I grabbed them. I currently have SL-DL1 (2 of these), SL-QL1, SL-5
A few thoughts:
* The SL-DL1's and the SL-QL1 are tanks - they weigh a ton and are seriously solid
* Both of the SL-DL1's are working, but second one I got is a bit beaten up. I've been running the arm back and forth down the rail to get it to flow more easily (it got stuck on the first album I played). He sent it with an Audio Technica AT3482P cartridge that didn't get much love on here. And he sent it without a stylus so no matter what I wasn't playing it, so I put on a Stanton 737 I have (I think with a Vivid Line stylus) and fired it up... Once I got the rails moving properly, it sounds really, really good. Will definitely need to get the right belt for the arm and replace it, and likely clear up the rail and insides so I can oil it up also
* I'm running the other SL-DL1 with the Technics P23 cartridge and a basic Pfanstiehl, and it sounds good, but the Stanton sounds better.. I'm going to see about a better stylus for this one though, as it sounds like it has potential. It's running a tad slow (just a tiny tic slow) and I want to deoxit the controls a bit and see if it clears up like it did with my SL-1400's speed. I also had to find the right angle to unscrew the lock screw on the cartridge, so I was using the P23 no matter what for a while!
* SL-QL1 arrived and wasn't completely working, so I changed the arm belt. Did that, but I think the place sent one too big as there is a lot of slack there. I'll revisit later as I have to work on cleaning and reoiling it anyway and may just take it to Stereo Rehab and let them give it a full once over
* The SL-5 appears to be working, but I need to get a ground wire for it. Apparently there are 2 kinds in the SL-5 and need to check tonight to see which one I have so I know which one to order (crazy, never would have thought that!).
* I probably wouldn't have gotten the SL-5, but it came with a Shure V15LT cartridge that adds to my p-mount collection. I'll probably switch the cartridge to something nicer and put one of my lower level cartridges on this one for pure casual listening
* given their age, they need some work, but 3 of 4 should be playing soon (once I get the ground), and look to not need tons of work. Fingers crossed that they'll
I have more than a few P-Mount cartridges to try now:
- Shure V15 V-P
- Shure V15LT
- Shure M110
- Pickering XSP-3003
- The Stanton 737 (the one I ran on one of the SL-DL1's)
- The Technics P23 (really need to try a better stylus for this one)
- Technics P22 (on the SL-QL1)
- think I have a shure M105 also
Will be fun to swap some of these in and do some side by side tests -- but need to go about selecting some decent styluses now
A few thoughts:
- Shure V15 V-P
- Shure V15LT
- Shure M110
