bingobelle
Hi
Need help to sort out some things.
First a "short" story what have happened.
I have a jvc jr-s400 receiver. All but two of the original bulbs where burned out so went to a audio shop and bought some new ones. I showed the guy that the fuse types should be 12 v and 150 mA. The small minibulbs where 6 Volts and 35 mA except the one for the dial pionter that is 6 Volt and 100 mA.
Anyway, he told me it does not matter some mA here or there and to be honest I´m not sure what lamp he gave me. The fuse type however I later saw that they where 300 mA so no wonder the fuses for the lamp circuit went after a couple of hours. the small minibulbs I´m not sure about but I guess they where 70 mA he gave me.
anyway, the minibulb did light very week and after looking some time on the circuit diagram I think I underdstand why, the minibulbs is connected in series with resistors becuase they are fed by the same stab circuit as the 12 volt fuse type lamps. So they have to have the correct mA because as I understand a for example a 70 mA 6 volt bulb have less resistance compared to a 6 Volt 35 mA bulb. So the correct bulb is very important to obtain the correct voltage drop over the bulb.
So the voltage over my bulb where only 4,5 Volt instead of 6 volt. hence the weak light.
Now to my question, instead of looking further for some other incandescent bulb I bought a led kit for my receiver on ebay.
I mounted the 4 fusetype led lamps and the 3 led minibulbs. all work but as I was worried about it is very brigtht. the small mini led acording to sellers store on ebay is made for 6 to 8 volt and the fuse type lamps ois made for 12 volt.
However, I measured the voltage now over the small led bulbs and the voltage is 10 volt. So as I understand it the resistance of those led lights is much higher compared to the original incandescent bulbs. So over the resistors it is now only 1,12 volt.
So, how will this affect the life expectancy of the led bulbs? 10 volt on a 6 to 8 volt led bulb?
also, how come it does not matter about the polarity? the led bulbs lights up regardless of what wire leaqd goes to ground or not. If I understand there is a rectifier on the stabilisation board. are those led bulbs that are sold for vintage audio gears some special led bulbs that do not care for polarizxation of the lead wires?
Should I solder in a drop resistor in the wire leads on the small led bulbs?
I did some calculations, should a 820 ohm resistor do the trick to achive about 6 volt over the led?
I attach the circuit diagram.
Now this post is already to long but hopefully someone can give me some hint or explonation.
Sorry for my very bad technical english but I do my best, english is not my native language.
Thanks!
Thanks!
