graywolf
Sonically Challenged
An idea came to me in the night. The supply voltage is 7.5 volts. The LED's are 1/2 that. So two in series is perfect. I took two soldered them together with about a 15 degree outward angle between them Then soldered hook up leads to the other legs and cut them all the legs short. I then pulled them back to the rubber boot and plugged the boot into the mounting hole making sure the LED's were horizontal. I also sanded the domes to make them somewhat wider angle and more defused. The results are very favorable.
