Vinyl Rules!
Well-Known Member
Mr. DeWick has my beloved MR74, MC2125 and MC2205 in for a tuneup and some burned-out bulb replacements.
I was wondering if anyone made replacement LED's for vintage McIntosh lamps and I discovered they were available from someone named Don Haywood.
Samples of his LED's can be viewed at http://vintage-electronics.home.bresnan.net/links.html below the name Don Haywood.
I emailed Mr. Haywood and he responded with the following info:
Your MR 74 tuner uses:
2X dial thin WHITE festoons 6.3 Volt
2X 1847 6.3 Volt meter lamps (Usually BLUE)
1X 1828 38 Volt RED mpx lamp
4X 1866 6.3V panel lamps (Usually GREEN)
A complete kit of LED lamps costs $xx.xx post paid.
My question: Has anyone had any experience they can comment on using these LED's as replacement bulbs in their Mac's?
I'm also wondering if LED's would be a better choice as meter lamps in vintage Mac SS amps as I assume they would generate less heat? I would welcome thoughts and personal experiences on this as well.
Thank you. :yes:
Thank you. :yes:
