celt_rock
Member
So I've been reading and Googling for the last two weeks trying to figure out why my Pioneer SX-650 is having issues. Is it me or does it seem like this is a common issue with the Pioneer SX series?
Anyway, here's what happens, sometimes I'll be playing music and the left channel will cut out almost completely, I'll still hear it faintly if I turn the balance all the way left but it sounds like a fly caught between two pieces of paper (or trying to get out a closed window). I found that sometimes just picking the needle up off the turntable would get it to come back while other times I gave my needle a gentle rub with the Magic Eraser in order to get it back. At one point I got so frustrated I (with one of the lesser quality records in my collection) forced the needle to jump a groove which got the left channel to kick back on.
So I thought it may be a speaker problem. Switched the speakers and same problem, just now a different speaker.
So I thought maybe it was just the A Channel. Nope, put both wires in B channel and still same problem, same left speaker
I swapped out cartridges on my turntable. Same. I swapped out the whole damn turntable! Same.
So then I came across a post describing the cleaning of the speaker relay. I spent one evening with a nice Vermont double IPA and a desoldering bulb, removed the relay, cleaned it and re-installed it.
I was riding high for 3 FULL DAYS of beautiful non-buzzing sound and then... you guessed it. It came back, maybe even worse than before.
So here's what works. When I digitize vinyl, the tape output which goes to my laptop gives strong signal from both channels.
If I move my selector switch from Stereo to Mono, all of a sudden I can hear both speakers, no more farting coming out of the left speaker.
So if it wasn't the relay, what gives? What could it be? And what would cause the speaker to work fine when given a mono signal but crap out (intermittently) when given a stereo signal? This is not a case of cleaning pots or deoxiting anything, it's internal and I know one of you has the answer, anyone wanna spill the beans? ;-)
