Toasted Almond
RIP 1952-2016
I picked up the $20 Lepai from PE awhile back. For what it is/cost, it is just fine. Nice to have something about the size of a deck of cards handy to test other electronics/speakers.
Perfect! :thmbsp:
I bought a similar one of those a few weeks back as well and did a little report on it in another thread re a basic TV amp application for which it would pretty well suited I think.
http://www.audiokarma.org/forums/showthread.php?t=344212&page=3
Mine is a Dian Xin Electron! It claims 12 watts per side, has an FM tuner, and came very clean with no Chinese dust inside or even any Chinglish to speak of. :thumbsdn:
Other than that it looks a lot like yours, with a tuner board added. I just took it out of the case to have a quick look and it was similar but not identical. No marking to indicate T amp or "Booze" branding...
As for power input, 13.8 form a car circuit should give no concerns for something rated 12v. This one did not come with a power supply either, but it is labeled "12-18V".
Mine might make into a scooter system for my Vespa, or maybe a bench testing device. Or just sit around collecting Canadian dust?
Can I tell you guys I feel like such an audio nerd, but am happier playing around with the T amp than I would be with, say, your average HT receiver, with its codecs I can't change, its HDMI I can't affect and the rest?
s.
I would buy one if it had tubes.![]()
"This is use Bose" ORLY?
I have more or less the same experience with the Lepais (tried 3 of them).
The SMSL amp03 is the one to look out for ime (~30 bucks shipped), decent build, great sound.
I got my lepai in about a week ago or so. Damn for the price this tiny little wonder is wonderful. I have it running a pair of very efficient and recently recapped (yesterday) EMI 529's. That 4ohm set up actually cranks. Running it from a 12 volt battery seems to be an upgrade from the walwart supplied with it as well. It's a great little toy and I'm quite pleased with the looks and the sound of it. Hmmm; I wonder what the next step up is like now.
T-amps really respond well to a hefty power source like an oversized power supply with beefy capacitors or a battery. It's easily the most rewarding basic upgrade you can make.
So is it possible to take a T amp, put in higher voltage caps then run it on a voltage over 16 Vdc?
