12ax7
OK, I'm only talking about a car speaker here but it's a warning for all. The JBL door speaker in my Solara developed a nasty raspy sound so I pulled the door panel and removed the speaker. The voice coil gap had developed some rust in it and the rust was interfering with a smooth "excursion". Well, since this is a 2 ohm speaker and unobtainium except from Toyota for $175, I thought I'd play with trying to fix it. Nothing to lose...right? I carefully razored the dust cap off and worked some 1500 grit around the inside of the coil on the magnet side to remove some rust and it did smooth things a bit. At that point, there's no way to get at the other side of the gap without cutting the spider....nope. My "bright" idea was to spray some Deoxit in the gap and use some low pressure compressed air to try to dislodge the rust particles. Wrong! As soon as the Deoxit hit the voice coil it locked up solid! I thought this stuff was pretty benign but it reacted almost instantly with the coil. I'm gonna have Billy Mays selling it on 2:00 AM TV next week as a super adhesive!
Hey, I'm not out anything, it was an experiment. Just be careful what you spray where.........
