You can use a single bleeder resistor anywhere on the B+ chain, as they're all connected together. As mentioned, it may drop the voltage too much at the "end", depending on the values of series resistors. At 300V and less, I'd use a 100K, 2W resistor for a bleeder. For up to 500V, 150K, 2W. The discharge time (in sec.) to about 1/3 voltage is R*C where R is the bleeder resistance in megohms, C is the total capacitance. Double this time and it'll be about 10% voltage, safe. So let's say you have 150 uF total in the power supply, 150K resistor. It'll take about 22 sec. to drop to 1/3, in 45 sec it will be down to 10%. If you are OK with a slower discharge, use double the resistor value at 1W. And of course use two resistors to cut the discharge time in half. I wouldn't use smaller than a 1W resistor, since smaller ones may not be rated for the voltage.
