Not bad for 61 years old. I just sold it last month to a guy who's collects '59 Epiphones and Gibsons and these are very rare, he seemed to want it more than me, I had it for 20 years.Very, very nice Epiphone! Still work well?
Here's my take on a hotted-up TW Rocket style amp, but with a full size board that places the circuit components closer to the tube sockets. Sort of point-to-point, but with an underlying board. This uses a bigger than usual dual voltage PT which I could switch by adjusting the rotational position of the tube socket and plug on the board near the switches and a custom OT. It also incorporates VVR, PPIMV, and my tone circuit mods that I put into all of my Rocket style amps, as well as SS protection for the tube rectifier, protection for the cathode follower, and polypropylene caps instead of polyester. A one-off, which I'll never repeat - too much trouble.
Thank you! I've built a lot of TW style and tribute amps, and have a beautiful, faithful Liverpool build using mostly identical components, and a couple of Express style amps, one that is pretty stock, the other with a few modifications. Most of mine are evolutions of the originals and not meant to be direct copies. The Express in your photos was built by JM, who now builds them by permission from Ken's estate.
I posted a photo earlier of this one I built, the cabinet for which I commissioned.
Started out as a JTM 45 with some modifications, but then I changed it to a JMP 50 style amp with more modifications, one or two that may not be shown in the gut shot. Aluminum chassis made it nice to work with, but things got a little tight. I make my circuit boards using my mill to drill, then press in turrets with it as well.
Series input for really high gain (took a lot of tweaking to make it manageable), parallel input for lower gain, 6 position rotary switch for cathode cap/resistor combinations, variable slope control, pre-PIMV, and post-PIMV, 10-turn bias pot, Russian paper in oil presence cap, variable NFB.
Can sound like a JTM 45 with nice cleans and no hum or hiss, or at highest settings, way too aggressive, hissy and shrill (but still stable) for my tastes these days. One day I'll make some adjustments, but it doesn't get played all that much with all the other amps in the room.
Original configuration before further modifications, with standard Marshall knobs
After first round of circuit mods, and now with walnut knobs.
Trainwreck amps are tone monsters. I bet that yours is very, very good. I love the response that Ken's amps have, to slight hand articulations and guitar settings.![]()
I also build my own pedalboards.
Too many, probably...but damn if I'm gonna let them sit in boxes...
