targeteye
I'll start off. If there is already a thread on the subject just point me in the right direction and i'll delete this one.
I say Hi-Fi stuff because obviously there is lots of radio related gear out there. I'm interested in seeing pics of the era when component stuff started being built for home use.
Here is my mid to late 40s Jensen Bass Reflex cabinet with a Jensen JAP-60 15" coax speaker installed. It is as I found it and needs a few hours of touchup work to look its best. I have nothing built to drive its 600 ohm impedance. In the pic its hooked up to a 150 Watt SS amp. It does put out enough voltage to get decent volume out of the speaker. Sounds a lot better than I expected to and somehow playing recordings originally intended to be mono do seem to be more involving to listen to playing thru it. (I know its all in my head).
I'm now on the hunt for an amp from the same era.
So what do you have? Lets see it?
One pic with flash one without. The lighting in this room is terrible for pictures.
Steve
Steve
