Kamakiri said:
Thought this would be a good weekend thread :yes:
Do any of you have any projects that are so bad, that fixing the thing and making it useable again would be like turning a turd back into a cheeseburger?
(Don'cha just love the analogy? :lmao: )
Now I don't wanna see pics of things that are DONE, show me some pics of things that are as they are, the stuff that's so bad that willl make us all scratch out heads as to why you'd bother
I have quite a few to choose from around here
ara:
I'll take some pics over the weekend, let's see yours!
Ok, I've been watching this thread, and I decided to liven things up a bit - tech wise...
The items are a pair of Hewlett Packard 3336B Synthesized Function / Level Generators. They make 10 Hz to 20 Mhz Low distortion sine waves at calibrated levels of about -70 dB to +6 dB into popular (OLD) phone company impedances. Very Accurate Levels.
In the pictures the unit on the right side or the bottom is the GOOD unit for comparison.
The LEFT and TOP unit however, fits Kams decription of turning a turd back into a cheeseburger.
The first view is the front panels..... just a few missing switches and keycaps.... and ALL the led's and 7 segmant displays behind the plastic!!!
The second view is the rear panel. Notice ALL the EMPTY HOLES. ALL the BNC connectors and the HPIB stuff is missing....
The third view is the bottom chassis. Yes the big board is there, and should work. But the mixer/ vco board (and some unobtanium custom parts on them), and output attenuator box are missing. What doesn't show well is that ALL the TNC custom length coaxial interconnect cables are MISSING, and another unit would have to die to supply them.
The fourth view is the top chassis. Yes the microprocessor board is present, but it's MISSING THE PROGRAM ROMS, all FOUR of them..... The missing board below it is the divider board, more unobtanium parts... as well as ALL needed coaxial harnesses between the boards (just like the bottom). Just when I was ready to relax, I saw the BUTCHERED (apologies to all professional meatcutters out there!!) Power Supply. The main filter cap is missing! The formerly socketed power pass transistors for the regulator have been soldered to jumpers, and their elegant frame mounting bracket is MISSING. Then I saw that the integrated circuits were missing and sockets substituted in their place with some of the worst soldering work done ever by a supposedly professional tech, TILTED sockets with pins barely into holes, holes barely soldered, bridges etc. Rabbi Rich, I think, once his eyes would focus on the hulk, would be impressed with the carnage here.
I take on lost causes....and don't give up easily, but this is one I decided NOT to sacrifice a better generator to make it live again. This IS a DONOR UNIT that I had intended to resurrect. I can replace the roms, I can replace the leds... I may even find the missing boards..... but those harnesses...... fuh..ged..abou...dit..........
The turd stays a turd.
