Let's see your modded Klipsch Heritage Speakers!
Gigantic
A big, big love
Since it's now banned in Hope, let's see your modified Heresies, Cornwalls, La Scalas, K-horns and any other classic Klipsch speakers that you've made your own!
Mine started out as a pair of 1971 H700 Heresy speakers that I rescued from a dumpster after a fire:
Time had not been good to them, nor had spending the past 16 years bouncing around in various garages and carriage houses in the Philly area. I couldn't stand listening to them, but I also couldn't bear thowing them out.
finally, after moving them for the millionth time, I decided to restore them. They got sanded and a fresh coat of paint:
And reassembled as stock, albeit with updated networks:
still, I was less than satisfied. They sounded a lot better, but they were still lacking. Enter my new friend @ClaudeJ1 and his Super Heresy 1.0 mods.
First step is a pair of Eminence Delta Pro 12A woofers:
and temporary MDS backs with 4" ports and uprated terminals, as I didn't want to damage the originals:
so far, so good, the cats approve!
they have all the magic of the original Heresy speakers, incredible clarity and liveliness, but thanks to the woofer and port mods, they also have apartment shaking bass!
it's great, but I'm not done yet! Friday, I'll receive a pair of these, @Daveintn's sMAHL tweeters with B&C DE120 Neodymium drivers:
that's not all! To address the shortcomings of the somewhat crude, 5/8" ply decorator series cabinets, I've decided to make my own boxes to put all the upgraded parts in, then I'll return the original cabs to stock. While, as a master carpenter and cabinet maker, it's certainly well within my skillset to make my own motor boards, it turns out that the ones sold by Crites are actually cheaper than making my own, so that will form the starting point of my new speakers. Stay tuned for the build:
Wow, those were pretty ratty to start with. Looking like an awesome resto-mod for them!
They were old badly conditioned Decorator models. I restored the cabinets and electronics. Flush mounted all top horns and veneered around them too. Top grills are magnetic with magnets under the veneer, so veneer is solid panels. I put a lot of hours into them!
16F61C3F-362D-4763-BE18-5FD8A8AD8A72.jpeg 5A14DE9A-AA6F-4C65-9BA1-A89C39141B0A.jpeg
You should post a selfie of your face when you first listen to them. Also Kudos to Dave. I'll even throw in a warranty. If you are not simply blown away with what they do, I'll buy them from you!
I think I’ve spent more on the sMAHL tweeters than on the rest of the speaker, combined. Do you realize how high expectations have been set? ;-)
I was just going down memory lane and realized I could have never been able to start or let alone complete any of my mods / builds
if I did not have the help of the vast knowledge of the more veteran members over at KC!
Colter, Claude, ChrisA, Coytee, Carl, Bob Crites, Moray James, jorjen, jwc, rigma, mark1101, and a host of many others.
Here are some of my kicks at the can...
Cornscalas
Different type of horn, Frugalhorns
How about a little bass, Cinema F-20
A trio of 4Pi Speakers
Jubilees... a ton of work went into to these!
Then came my beater LSs
Heresy3, built from scratch with H3 kits.
I actually built 5 of these, two reside in a good buddy's livingroom... he is a happy camper!
For some reason I could not find any good pics, but there are my 2 Exodus Anarchy 25hz TH sub, between the H3s
Peavey FH-1s with custom top hat that houses a K 510 (Faital HF200)
Then my current set up, FH-1s with K 402 (K 691) on top of the K 510 top hat which is not connected.
Running FH-1s / K 402 as 2way via Xilica XP-4080.
For fun and comparison, I can switch the K 510 for the K402 and go to my appropriate Xilica setting.
Huge thanks to Chris A for his help in dialing in the Xover!!!
Gorgeous work. The F-20 brings back memories. I think I've built 3 so far.
Hey Carl,
Thanks, it was your Klipsch Forum F-20 build thread that pushed me over the edge to build mine.
I even copied your router choice and went out and got my Dewalt on your recommendation. :thumbsup: :thumbsup:
Hey Carl,
Seems like forever ago. I just looked. I joined the Klipsch forum in 2004.
That Dewalt is a good one. I used it again about 2 weeks ago.
