I got a pair of SCII’s as part of a trade recently with a known issue. There is very low bass output below 160hz or so. I tested the woofers individually, they definitely are able to hit the lower notes when not hooked up to the crossover and the mids and highs sound wonderful. I removed the crossover plate and thankfully it’s only a first order low pass- the high pass is much more in depth. I was able to determine that it uses a 2.7uf 400v Solen poly cap and a 10 watt 2ohm audio grade resistor but I can’t find any values on the inductor. Nothing appears to be blown or damaged but the owner said that their house does get lightning strikes often so my question is, should I find a way to measure the inductor to replace it or is it unlikely to be out of spec? Also if there are any recommendations for getting quality caps- I’m thinking i would stick to exact replacement from Solen since there’s a lot of science and measurements behind the design of the SCII’s.
Both speakers have the same exact issue so whatever did happen to them happened at the same time or to the same components. I read on another thread for SCIII’s that someone had the same component fail in both, which was the inductor. Any insight is appreciated I want to get the SCII’s sounding to their fullest potential. I’ve never recapped a pair of speakers before since they’re usually in and out of the house but these are worth putting the extra time into.
. Read the reviews.
