Hello!
I’m newer to fixing record players and this is my first time trying to troubleshoot a linear player, looking for some advice .
it’s a weird problem im trying to figure out , power indicator lights up , but will not respond to any buttons pushed.
At first I thought it was a problem with the stylus assembly motor, but the motor returns the stylus to the home position when I manually move the assembly to the center of the platter ; so I’m pretty sure the motor is fine .
I tried turning the unit on with the stylus in the center of a record and pressing play to see if that would get any movement from the record but to no avail .
I’m not sure how the linear tracking system checks work, e.g if the stylus is suppose to move first then it’ll spin the record, or if the record has to be spinning before the stylus moves .
I tried manually spinning the player after pressing “play” but that doesn’t do anything either .
I checked the wires and capacitors on the main board and they all looked fine .
If anyone has any insight on how to fix this please share .
Right now I’m thinking about replacing the platter motor (pioneer pxm - 133) to see if that fixes it , but I’m not sure as the unit doesn’t even function when manually turned .
I attached some photos for context , thanks !
